An error appears when I am trying to send an analytic event
2021-09-27 18:37:13.591 UTC+02:00 Error StoreStateForBaseEvent Exception source: VideoOS.Event.Server
Exception type: System.NullReferenceException
Exception message: La référence d’objet n’est pas définie à une instance d’un objet.
Exception target site: StoreStateForBaseEvent
à VideoOS.Event.Server.MIP.CommunicationService.CommunicationService.StoreStateForBaseEvent(BaseEvent baseEvent)
which is the reason behind this error?
Can you please check if Analytics event settings is enabled on Management Client? Start Management Client – Tools – Options – select Analytics Events tab – Check on Enabled in Analytics Events.
Do you send Analytics Event via protocol to port 9090 or send Analytics Event via the messaging (MessageId.Server.NewEventCommand)?
