I am seeking an end-to-end configuration guide to stream rich analytics metadata (objects, bounding boxes, polygons, and attributes) from Axis P3268-LVE / Avigilon 8.0C-H5A-PTZ cameras to Milestone XProtect Professional+ (2023/2025).
Specifically, I need the required steps within the Camera Web-UI and the Milestone Management Client to ensure these edge-triggered events are captured as metadata rather than just simple alerts.
Could you also provide the specific REST API endpoint(s) required to retrieve Analytics Event metadata?
Please provide technical documentation or video references if available.
