Any workarounds for "The calling thread must be STA, because many UI components require this." error?
Hi, I am currently creating a plugin that would show a camera window (via ShowCamerasInFloatingWindowCommand) when a link is click on a website which is in a Workspace that contains a ChromiumWebBrowser tag.
The link throws a Javascript command in which the plugin catches, but I get a STA error: “The calling thread must be STA, because many UI components require this.” in Milestone Xprotect Client. Here a some code snippets.
//this is in public partial class ProjectWorkSpaceViewItemWpfUserControl : ViewItemWpfUserControl
public ProjectWorkSpaceViewItemWpfUserControl()
            InitializeComponent();
            CefSharpSettings.LegacyJavascriptBindingEnabled = true;
            this.Browser.RegisterJsObject("metagrated", proxy);
//This is the Execution of the Javascript command.
public void Execute()
                var data = new ShowCamerasInFloatingWindowData();
                data.Cameras = new List<Item>() { cameraItem };
                data.BrowseTime = DateTime.Now;
                data.Mode = Mode.ClientPlayback;
                EnvironmentManager.Instance.SendMessage(new Message(
                    MessageId.SmartClient.ShowCamerasInFloatingWindowCommand)
                    Data = data
Hi. This problem is not SDK but general .NET thing. Try invoking your code into the UI dispatcher:
       this.BeginInvoke((Action)delegate ()
           EnvironmentManager.Instance.SendMessage(new VideoOS.Platform.Messaging.Message(
               Data = data
The BeginInvoke method is on any System.Windows.Forms.Control.
On SC you can also use ClientControl.Instance.CallOnUiThread(() => { code }
Freddy
