API Patch call to update hardwaredriversettings
I am wanting to change httpSEnabled from no to yes on all my cameras. I can find the setting down in hardware/ID/hardwaredriversettings. i try to patch to that and it says “Message”: “The requested resource does not support http method ‘PATCH’.”
So I look back at the api reference sheet and should be able to patch to /hardware/{id}
I’m having trouble figuring out the body structure to patch this properly and keep on getting errors. My latest try is:
"array": \[
        "displayName": "Settings",
        "hardwareDriverSettings": {
            "httpSEnabled": "yes",
but get this response.
"error": {
    "httpCode": 404,
    "details": \[
            "property": "array",
            "errorText": "Element group not found"
Is this even possible?!
figured it out finally on my own, had to patch
https://(milestoneserver)/api/rest/v1/hardwaredriversettings/(CameraID)
with
“hardwareDriverSettings”:
and that worked!
