API to lookup GUID for ONVIF Bridge RTSP streams
We want to open selected RTSP streams from the ONVIF Bridge for XProtect Enterprise without the user’s having to enter the GUID. How can we get a list of available GUIDs so that users can open the RTSP streams without copy/paste of each GUID?
The ONVIF bridge support the normal ONVIF standards for retrieving the configuration, and that includes the GUIDs.
If you like to use the MIP SDK, you can also login once and get the entire configuration, and pick out the GUIDs from the cameras FQID.ObjectId - it is the same GUIDs.
