Are Verkada cameras supported?
Are Verkada cameras supported via MIP SDK or ? Are there any drawbacks or potential issues using these camera with Milestone 2024 R2 Xprotect Corporate?
With the MIP SDK and the Driver Framework you should be able to develop a driver for cameras that are otherwise not supported.
Read about the Driver Framework here - https://doc.developer.milestonesys.com/mipsdk/index.html?base=gettingstarted/intro_driverframework.html&tree=tree_1.html
The cameras that have drivers from Milestone and have been through a testing process are all mentioned here - https://www.milestonesys.com/support/software/supported-devices/xprotect/
There might be tips and tricks so that you can use the cameras that are not on the supported list (without developing your own driver), in that case you should seek advise from the partners using the support community.
