How can I connect the rest api with basic user over https, ¿I need to do something in the Management Client?
The RestAPI uses HTTP if the setup is not secure, and uses HTTPS if the setup is secure. With this I mean that using the Server Configurator you can enable secure communication with encryption by assigning a certificate.
There is a guide here. https://doc.milestonesys.com/latest/en-US/system/security/certificates/sg_aboutthisguide.htm?tocpath=Tools%20%2526%20Architecture%7CXProtect%20VMS%20certificates%20guide%7C_certificates_%7C_____1
