Authorization issue sending a SOAP request
Hello everyone.
I seem to be having an issue when trying to authorize a basic user using the following endpoint:
/ManagementServer/ServerCommandServiceOAuth.svc
My credentials are correct as I’ve used them to sign into the management client however I seem to get a 401 error when trying to authorize to this endpoint.
Here are the settings I am using.
XML body:
<soap:Envelope xmlns:xsi=http://www.w3.org/2001/XMLSchema-instance xmlns:xsd="http://www.w3.org/2001/XMLSchema"
  xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
  <soap:Body>
    <Login xmlns="http://videoos.net/2/XProtectCSServerCommand">
      <instanceId>95d088f2-73e6-4cbb-9718-dc16942b337a</instanceId>
    </Login>
  </soap:Body>
</soap:Envelope>
Current headers
The response I’m getting back is the following:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>IIS 10.0 Detailed Error - 401.1 - Unauthorized</title>
<style type="text/css">
body{margin:0;font-size:.7em;font-family:Verdana,Arial,Helvetica,sans-serif;}
code{margin:0;color:#006600;font-size:1.1em;font-weight:bold;}
.config_source code{font-size:.8em;color:#000000;}
pre{margin:0;font-size:1.4em;word-wrap:break-word;}
ul,ol{margin:10px 0 10px 5px;}
ul.first,ol.first{margin-top:5px;}
fieldset{padding:0 15px 10px 15px;word-break:break-all;}
.summary-container fieldset{padding-bottom:5px;margin-top:4px;}
legend.no-expand-all{padding:2px 15px 4px 10px;margin:0 0 0 -12px;}
legend{color:#333333;;margin:4px 0 8px -12px;_margin-top:0px;
font-weight:bold;font-size:1em;}
a:link,a:visited{color:#007EFF;font-weight:bold;}
a:hover{text-decoration:none;}
h1{font-size:2.4em;margin:0;color:#FFF;}
h2{font-size:1.7em;margin:0;color:#CC0000;}
h3{font-size:1.4em;margin:10px 0 0 0;color:#CC0000;}
h4{font-size:1.2em;margin:10px 0 5px 0;
}#header{width:96%;margin:0 0 0 0;padding:6px 2% 6px 2%;font-family:"trebuchet MS",Verdana,sans-serif;
 color:#FFF;background-color:#5C87B2;
}#content{margin:0 0 0 2%;position:relative;}
.summary-container,.content-container{background:#FFF;width:96%;margin-top:8px;padding:10px;position:relative;}
.content-container p{margin:0 0 10px 0;
}#details-left{width:35%;float:left;margin-right:2%;
}#details-right{width:63%;float:left;overflow:hidden;
}#server_version{width:96%;_height:1px;min-height:1px;margin:0 0 5px 0;padding:11px 2% 8px 2%;color:#FFFFFF;
 background-color:#5A7FA5;border-bottom:1px solid #C1CFDD;border-top:1px solid #4A6C8E;font-weight:normal;
 font-size:1em;color:#FFF;text-align:right;
}#server_version p{margin:5px 0;}
table{margin:4px 0 4px 0;width:100%;border:none;}
td,th{vertical-align:top;padding:3px 0;text-align:left;font-weight:normal;border:none;}
th{width:30%;text-align:right;padding-right:2%;font-weight:bold;}
thead th{background-color:#ebebeb;width:25%;
}#details-right th{width:20%;}
table tr.alt td,table tr.alt th{}
.highlight-code{color:#CC0000;font-weight:bold;font-style:italic;}
.clear{clear:both;}
.preferred{padding:0 5px 2px 5px;font-weight:normal;background:#006633;color:#FFF;font-size:.8em;}
</style>
</head>
<body>
<div id="content">
<div class="content-container">
  <h3>HTTP Error 401.1 - Unauthorized</h3>
  <h4>You do not have permission to view this directory or page using the credentials that you supplied.</h4>
</div>
 <fieldset><h4>Most likely causes:</h4>
  <ul> 	<li>The username supplied to IIS is invalid.</li> 	<li>The password supplied to IIS was not typed correctly. </li> 	<li>Incorrect credentials were cached by the browser.</li> 	<li>IIS could not verify the identity of the username and password provided.</li> 	<li>The resource is configured for Anonymous authentication, but the configured anonymous account either has an invalid password or was disabled.</li> 	<li>The server is configured to deny login privileges to the authenticating user or the group in which the user is a member.</li> 	<li>Invalid Kerberos configuration may be the cause if all of the following are true:</li> 	<ul> 		<li>Integrated authentication was used.</li> 		<li>the application pool identity is a custom account.</li> 		<li>the server is a member of a domain.</li> 	</ul> </ul>
 </fieldset>
</div>
 <fieldset><h4>Things you can try:</h4>
  <ul> 	<li>Verify that the username and password are correct, and are not cached by the browser.</li> 	<li>Use a different username and password.</li> 	<li>If you are using a custom anonymous account, verify that the password has not expired.</li> 	<li>Verify that the authenticating user or the user's group, has not been denied login access to the server.</li> 	<li>Verify that the account was not locked out due to numerous failed login attempts.</li> 	<li>If you are using authentication and the server is a member of a domain, verify that you have configured the application pool identity using the utility SETSPN.exe, or changed the configuration so that NTLM is the favored authentication type.</li> 	<li>Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click <a href="http://go.microsoft.com/fwlink/?LinkID=66439">here</a>. </li> </ul>
 </fieldset>
</div>
 <fieldset><h4>Detailed Error Information:</h4>
  <div id="details-left">
   <table border="0" cellpadding="0" cellspacing="0">
    <tr class="alt"><th>Module</th><td>&nbsp;&nbsp;&nbsp;BasicAuthenticationModule</td></tr>
    <tr><th>Notification</th><td>&nbsp;&nbsp;&nbsp;AuthenticateRequest</td></tr>
    <tr class="alt"><th>Handler</th><td>&nbsp;&nbsp;&nbsp;svc-Integrated-4.0</td></tr>
    <tr><th>Error Code</th><td>&nbsp;&nbsp;&nbsp;0x8007052e</td></tr>
   </table>
  </div>
  <div id="details-right">
    <tr class="alt"><th>Requested URL</th><td>&nbsp;&nbsp;&nbsp;https://milestone-1.deeprec.local:443/ManagementServer/ServerCommandServiceOauth.svc</td></tr>
    <tr><th>Physical Path</th><td>&nbsp;&nbsp;&nbsp;C:\Program Files\Milestone\XProtect Management Server\IIS\ManagementServer\ServerCommandServiceOauth.svc</td></tr>
    <tr class="alt"><th>Logon Method</th><td>&nbsp;&nbsp;&nbsp;Not yet determined</td></tr>
    <tr><th>Logon User</th><td>&nbsp;&nbsp;&nbsp;Not yet determined</td></tr>
   </table>
   <div class="clear"></div>
  </div>
 </fieldset>
</div>
 <fieldset><h4>More Information:</h4>
  This error occurs when either the username or password supplied to IIS is invalid, or when IIS cannot use the username and password to authenticate the user.
  <p><a href="https://go.microsoft.com/fwlink/?LinkID=62293&amp;IIS70Error=401,1,0x8007052e,17763">View more information &raquo;</a></p>
  <p>Microsoft Knowledge Base Articles:</p>
 <ul><li>907273</li><li>871179</li><li>896861</li></ul>
 </fieldset>
</div>
</div>
</body>
</html>
I’ve noted that this is an IIS issue and I’m wondering if there are some settings I need to configure for it to get SOAP requests to authenticate.
Have you tried if our sample LoginDotNetSoap works?
https://github.com/milestonesys/mipsdk-samples-protocol
It shows how to login through servercommandservice and will identify if there is an issue with your code or your server.
If you still have problems, please give us the following information:
  • Version of XProtect
  • Windows server version
  • Which programming language are you using
  • Are you making a service, application or something else?
Hello, sorry for the late reply.
I’m currently using XProtect R3 2022
Windows server 2019
Currently just making an XML request through postman
I am making an application that will use a SOAP request to create a VOD.
I have tried using the loginDotNetSoap and it works fine.
When the sample works, then we know its not an issue with the IIS or the VMS. Unfortunately we havn’t got much experience using postman to access SOAP services.
My suggestion is to look into the sample and how it get its binding. If you look into ManagementServerOAuthHelper.GetOAuthBinding you can see how the http binding is setup. Maybe some of theses configurations should be done in Postman.
Also look at the NtlmConnection.Login, focus on how the accessToken (which is retrieved from the IDP server) is added to the EndPointBehavior. I guess in postman, you can just add it to the authorization header.
