Hi everyone we have been trying to implement with Milestone for a few days and all the tests ive made on .net Form applications or even .net Console applications have worked without an issue, so when i tried to convert this over to a .net 4.7.2 or .net 4.8 .net web application, there seems to be some large issues with DLLs that i just cant seem to figure out. im stuck with the error page:
[FileNotFoundException: Could not load file or assembly ‘AVIExporterClientMW.DLL’ or one of its dependencies. The specified module could not be found.]
System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +0
System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) +232
System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean forIntrospection) +113
System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +23
System.Reflection.Assembly.Load(String assemblyString) +35
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +48
[ConfigurationErrorsException: Could not load file or assembly ‘AVIExporterClientMW.DLL’ or one of its dependencies. The specified module could not be found.]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +767
System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +256
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +58
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +287
System.Web.Compilation.BuildManager.GetPreStartInitMethodsFromReferencedAssemblies() +69
System.Web.Compilation.BuildManager.CallPreStartInitMethods(String preStartInitListPath, Boolean& isRefAssemblyLoaded) +137
System.Web.Compilation.BuildManager.ExecutePreAppStart() +172
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException) +854
[HttpException (0x80004005): Could not load file or assembly ‘AVIExporterClientMW.DLL’ or one of its dependencies. The specified module could not be found.]
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +111
System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +719
I have these nuget packages installed for Milestone
MilestoneSystems.VideoOS.Platform version 23.2.1
MilestoneSystems.VideoOS.Platform.SDK version 23.2.1
The DLL is located in bin.
i know the bindings are loaded as i viewed it using Assembly Binding Log Viewer (FUSLOGVW)
Log:
*** Assembly Binder Log Entry (09/11/2023 @ 15.06.08) ***
The operation was successful.
Bind result: hr = 0x0. The operation completed successfully.
Assembly manager loaded from: [C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll](file:C:/Windows/Microsoft.NET/Framework64/v4.0.30319/clr.dll)
Running under executable [C:\Program](file:C:/Program) Files\IIS Express\iisexpress.exe
-– A detailed error log follows.
=== Pre-bind state information ===
LOG: DisplayName = AVIExporterClientMW
(Partial)
WRN: Partial binding information was supplied for an assembly:
WRN: Assembly Name: AVIExporterClientMW | Domain ID: 2
WRN: A partial bind occurs when only part of the assembly display name is provided.
WRN: This might result in the binder loading an incorrect assembly.
WRN: It is recommended to provide a fully specified textual identity for the assembly,
WRN: that consists of the simple name, version, culture, and public key token.
WRN: See whitepaper http://go.microsoft.com/fwlink/?LinkId=109270 for more information and common solutions to this issue.
LOG: Appbase = file:///C:/Users/uhrsk.MSI/Source/Repos/xGuysOG/StoreSyncAPI/StoreSyncAPI/
LOG: Initial PrivatePath = [C:\Users\uhrsk.MSI\Source\Repos\xGuysOG\StoreSyncAPI\StoreSyncAPI\bin](file:C:/Users/uhrsk.MSI/Source/Repos/xGuysOG/StoreSyncAPI/StoreSyncAPI/bin)
LOG: Dynamic Base = [C:\Users\uhrsk.MSI\AppData\Local\Temp\Temporary](file:C:/Users/uhrsk.MSI/AppData/Local/Temp/Temporary) ASP.NET Files\vs\1dba7bd2
LOG: Cache Base = [C:\Users\uhrsk.MSI\AppData\Local\Temp\Temporary](file:C:/Users/uhrsk.MSI/AppData/Local/Temp/Temporary) ASP.NET Files\vs\1dba7bd2
LOG: AppName = 8a992f58
Calling assembly : (Unknown).
LOG: This bind starts in default load context.
LOG: Using application configuration file: [C:\Users\uhrsk.MSI\Source\Repos\xGuysOG\StoreSyncAPI\StoreSyncAPI\web.config](file:C:/Users/uhrsk.MSI/Source/Repos/xGuysOG/StoreSyncAPI/StoreSyncAPI/web.config)
LOG: Using host configuration file: [C:\Users\uhrsk.MSI\Documents\IISExpress\config\aspnet.config](file:C:/Users/uhrsk.MSI/Documents/IISExpress/config/aspnet.config)
LOG: Using machine configuration file from [C:\Windows\Microsoft.NET\Framework64\v4.0.30319\config\machine.config.](file:C:/Windows/Microsoft.NET/Framework64/v4.0.30319/config/machine.config.)
LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
LOG: Attempting download of new URL file:///C:/Users/uhrsk.MSI/AppData/Local/Temp/Temporary ASP.NET Files/vs/1dba7bd2/8a992f58/AVIExporterClientMW.DLL.
LOG: Attempting download of new URL file:///C:/Users/uhrsk.MSI/AppData/Local/Temp/Temporary ASP.NET Files/vs/1dba7bd2/8a992f58/AVIExporterClientMW/AVIExporterClientMW.DLL.
LOG: Attempting download of new URL file:///C:/Users/uhrsk.MSI/Source/Repos/xGuysOG/StoreSyncAPI/StoreSyncAPI/bin/AVIExporterClientMW.DLL.
LOG: Assembly download was successful. Attempting setup of file: [C:\Users\uhrsk.MSI\Source\Repos\xGuysOG\StoreSyncAPI\StoreSyncAPI\bin\AVIExporterClientMW.dll](file:C:/Users/uhrsk.MSI/Source/Repos/xGuysOG/StoreSyncAPI/StoreSyncAPI/bin/AVIExporterClientMW.dll)
LOG: Entering download cache setup phase.
LOG: Assembly Name is: AVIExporterClientMW, Version=1.0.0.0, Culture=neutral, PublicKeyToken=7e3bf503659a8cbe
LOG: A partially-specified assembly bind succeeded from the application directory. Need to re-apply policy.
LOG: Post-policy reference: AVIExporterClientMW, Version=1.0.0.0, Culture=neutral, PublicKeyToken=7e3bf503659a8cbe
LOG: GAC Lookup was unsuccessful.
LOG: Binding succeeds. Returns assembly from [C:\Users\uhrsk.MSI\AppData\Local\Temp\Temporary](file:C:/Users/uhrsk.MSI/AppData/Local/Temp/Temporary) ASP.NET Files\vs\1dba7bd2\8a992f58\assembly\dl3\172f7fe6\00809fed_cd94d901\AVIExporterClientMW.dll.
LOG: Assembly is loaded in default load context.
I hope someone has met a similar issue or just has any idea of what i might have done wrong?
