I currently have the above mentioned Avigilon IP camera. How can I use it’s digital input on the camera to trigger an alarm on the client PC. Our access control panel will send a closed state during a door held alarm to the camera’s digital input but I’m looking for a way for it to report back to Milestone using TCP or any other method that works.
Camera I/O should be supported.
It should be possible to use the regular functionality of the XProtect Professional so I do think it is necessary for you to develop anything.
