AXIS Network I/O Relay Module and HTTP Notification
Looking for a way for an AXIS A9210 Network I/O Relay Module to send a notification to a Milestone System without pulling the device into the system via “Add Hardware” wizard (i.e. not using drivers to communicate).
Specifically, we want to have the AXIS module send an HTTP notification to Milestone when an I/O port is triggered via a configured event, and when Milestone receives that notification, to trigger a different event or alarm. Please advise if this is possible. Thank you!
Recommendation:
Add this as a supported device. It has been thoroughly tested and is widely recognized for reliability.
Integration Approach:
Using the MIP SDK, you can build an application that listens for notifications from the device and converts them into user-defined events or analytics events.
Event Handling Considerations:
If your goal is to configure the device so it sends events that can be consumed as generic events—without custom development—this may not be feasible. Since this involves pure configuration rather than coding, you’ll likely get better guidance from partners through https://supportcommunity.milestonesys.com.
