Azure Cognitive Services Face and Multi-stream:
I am trying to find where to start with giving Azure Cognitive services Face (AI) access to camera streams. For object/facial recognition. Can I use Xprotext multistream to send to archive and the other stream to allow Azure Cognitive services API to view the second stream.
Can you please add some context and elaborate on your question?
I can us Azue cognitive services Face AI to connect to a stream on a camera and use the AI for facial recognition for motion events and extract frames from the live feed.
I rather the Azure AI app get the stream from the Xprotect VMS. Rather it be via SDK or using a feature like Multistream.
I am wonder which is the best approach. Also my customer needs to ingest video to the drive of the VMS as they normally would will Azure does its thing.
thx
Maybe you would be able to use JpegLiveSource -
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_live_1_1_j_p_e_g_live_source.html&tree=tree_search.html?search=jpeglivesource
