I’m creating a plug-in. The Plug-in is installed , visible ( and controllable ) in the management client. But the BackgroundPlugin does not seem to be loading. I really am lost on this, other plug-ins do load and show up in event log :
example
BackgroundPlugin.Init(), in randomBackgroundPlugin
Please check if you have following setting in your code:
/// <summary>
/// Define in what Environments the current background task should be started.
/// </summary>
public override List<EnvironmentType> TargetEnvironments
get { return new List<EnvironmentType>() { EnvironmentType.Service }; } // Default will run in the Event Server
Also please try to restart Event Server When you deploy your plugin.
Found the problem, there was an issue with the resources file for some reason, so i removed all and added them again. Resources used some .png files for pictograms. No idea why they did not load, but this fixed it.
