BACNet integration - driver, tools and developer tester software.
I would like to ask you about BACNet integrations with XProtect. The BACNet service suplied by Milestone cannot communicate with devices nor as a ‘client’ neither as ‘server’. So, I would like to try to develop by myself. How could I start?
Tks
My insight into BACNet is so limited that I would be guessing. One page in the SDK documentation seems relevant..
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/io_systems_building_management.html&tree=tree_4.html
Hi, Mr. Andersen.
Pls. How could I get documentation about BACNet device integration?
Is there any BACNet template like access control’s one?
I’m not fiding information about this issue.
Tks again,
Hi Jose,
Which BACNet integration have you tried and what was the problem you faced with it?
My team is the one responsible for the integration provided by Milestone: https://download.milestonesys.com/CustDev/MilestoneBACnetIntegration/latest/
So, I wonder whether you had problems with it or some other integration.
Best regards,
Anton Polimenov
Engineering Manager
Custom Development EMEA
Milestone Systems
I suspect you might not have tried any integrations made by Milestone or third parties.
In that case the answer is that the MIP SDK does not include any information on how to do BacNet, there is no template or sample code. The documentation contains a lot of information about using the MIP SDK but nothing on BACNet.
A last hope could be that other partners that have worked with BACNet will share their experience and answer here in the thread..
A search on Milestone’s Technology Partner Finder - Milestone Systems Technology Partners
