Batch update hardware's ID, Password with MIP SDK 2017 R1
Dear Milestone team,
I would like to know whether it is possible to batch update hardware’s ID and Password with MIP SDK 2017 R1.
If possible, then please guide us which part of SDK should be used.(ex : [C:\Program](file:C:/Program) Files\Milestone\MIPSDK\ComponentSamples\ConfigApiClient\ConfigApiClient)
The installed XPCO version is 2017 R1, so please guide us with MIP SDK 2017 R1.
This is batch update but ever camera’s ID, password is not same. : Different ID and Password is assigned to each camera. (ex : camera 1 id/pw - admin/1234 change to user1/4321 , camera 2 id/pw - root/pass change to post/1111 etc…)
This installation is a high level security site, so every 3 months all IP devices’ ID and Password must be changed(included camera)
Thank you and best regards,
Lee
Run the Config API Client sample and pick the hardware and note the Change hardware password button/functionality. The task is then to adopt the programming from that sample to develop a batch utility that can change the camera password.
PS. To me it is a very odd requirements that you want to use an old MIP SDK, I must strongly recommend you use the newest availble MIP SDK when you begin an integration development project.
