Hello, I am currently using the following code to retrieve Hanwha Vision cameras.
IEnumerable<Hardware> hardwares = ms.RecordingServerFolder.RecordingServers
.Where(rs => rs.HardwareFolder != null)
.SelectMany(rs => rs.HardwareFolder.Hardwares);
var hardwareList = hardwares.ToList();
foreach (Hardware h in hardwareList)
if (h.CameraFolder == null || h.CameraFolder.Cameras == null || h.CameraFolder.Cameras.Count == 0)
continue;
Guid deviceId = Guid.Empty;
string model = h.GetProperty("Model");
if (model == null)
continue;
// Check if it's a Hanwha camera
if (model.ToUpper().Contains("HANWHA") == false)
continue;
ICollection<Camera> cams = h.CameraFolder.Cameras;
if (cams != null)
List<Camera> hanwhaCameras =
cams
.ToList();
The current code is very slow, especially when looping through the hardwareList. Could you recommend a way to get a specific vendor’s (Hanwha) camera list with better performance?
