I would like to get an image from a specific camera, defined in the XProtect application.
I’m using C#.
All the samples I have found use the default forms to connect to the server and get the camera info.
In my application I can’t open a form. I have a configuration file and I need to pull the textures via web.
I found a sample to show how to connect to the server, but I can’t find anything about enumerating the cameras and pulling the images.
Thank you
