I am developing C++ application to get live streaming of cameras. I am trying to modify existing MediaLiveServiceJPEG example to get raw images.
I want data in unsigned char* BGR24 format so that I can use it with OpenCV
Here is how am trying to modify config.
utf8_string_t config = "<?xml version='1.0' encoding='utf-8'?>"
"<toolkit type='source'>"
" <provider>mmp</provider>"
" <config>"
" <image_color_format_convert format = 'BGR24'> "
//" <jpeg_encoder quality='90' quality_update_key='qual'>"
" <video_decoder number_of_threads='-1'>"
" <toolkit type='source'>"
" <provider>is</provider>"
" <config>"
" <server_uri>"+ vmsRecorderUri +"</server_uri>"
" <device_id>"+ cameraGuid +"</device_id>"
" <media_type>VIDEO</media_type>" + authorizationToken +
" <maximum_queue_size>5</maximum_queue_size>"
" </config>"
" </toolkit>"
" </video_decoder>"
//" </jpeg_encoder>"
" </image_color_format_convert> "
" </config>"
"</toolkit>";
Even though, frame is received, am not able to actually read data. May I also please know how to get image width, height and fps?
I will really appreciate any kind of help.
@Bo Andersen ,@Michael Wahlstrøm (Milestone Systems) , will you please help ?
About Media Toolkit (a tutorial)-
http://doc.developer.milestonesys.com/html/index.html?base=mmtkhelp/tutorial.html#connecting_to_a_source&tree=tree_2.html
Note that what I understand from what you are writing you do not want raw data but the images in bitmap format. This should be achievable.
Hi @Bo Ellegård Andersen (Milestone Systems) , Thanks for the reply. I have gone through the shared link. Yes I want bitmap image data in BGR24 format instead of raw data. I feel, I need to use image_color_format_convert transformation from Media Processing Source Toolkit.
I have modified existing MediaLiveServiceJPEG.cpp file as follows.
// Downcast to live source toolkit interface
ImLiveSourceToolkit *liveSourceToolkit = ynamic_cast<ImLiveSourceToolkit *>(sourceToolkit);
if (liveSourceToolkit == 0)
cerr << "Created source toolkit does not implement the live source toolkit interface!" << endl;
else
std::wcerr << "... Starting video stream" << std::endl;
liveSourceToolkit->StartLiveStream();
long ix = 1;
DWORD ftyp = GetFileAttributesA("C:\\Data");
if (ftyp == INVALID_FILE_ATTRIBUTES) {
CreateDirectory(L"C:\\Data", NULL);
unsigned char* imageData;
int count = 0;
while (!_kbhit())
ImLiveSourceToolkit::get_live_status_t liveDataResult =
liveSourceToolkit->GetLiveData(data, 10000);
if (liveDataResult == ImLiveSourceToolkit::LIVE_DATA_RETRIEVED)
mImMediaData *mediaData = dynamic_cast<ImMediaData *>(data);
mediaData->GetProperty()
if (mediaData != 0)
std::wcerr << "... Frame Received" << std::endl;
const byte* b1 = mediaData->GetMediaBodyPointer();
size_t b2 = mediaData->GetMediaBodySize();
if (count == 0) {
imageData = (unsigned char*)malloc(sizeof(unsigned char)*576*960*3);
count = 1;
memcpy(imageData, mediaData->GetMediaBodyPointer(), mediaData->GetMediaBodySize());
cv::Mat Img(576, 960, CV_8UC3,data);
imshow("image", Img);
waitKey(0);
I am able to receive frame, However, mediaData->GetMediaBodyPointer() returns null and size from mediaData->GetMediaBodySize() is also zero.
May I please know what I am doing wrong in the code. also, I am still clueless how to get width and height of received image.
Hi Ankita,
I think your issue is that you need to cast it to ImImage class as this is the actual data that you get.
Please read more here:
Hi @Artur Magaljan (Milestone Systems) ,
Yes. The problem was indeed ImImage. I am now getting output as expected.
I have one small question though. Does Milestone add padding to images? ImImage has two functions getimagewidth() and getplanestride(). For few videos I checked, there were no extra bits.
Hi @[Artur Magaljan] ,
Yes. The problem was indeed ImImage. I am now getting output as expected. Thanks a lot
Hi Ankita,
It depends on the format and it it is needed. we do not add anything to images if not a “must”.
But i guess for your needs you can just call getimagewidth and getimageheight to get the resolution of the image.
Artur.
