Camera Permission
How to know if a user, not the one logged in, has permission to access a camera?
Many Thanks,
Frediano
You can use
static bool VideoOS.Platform.Util.SecurityAccess.IsMember( ServerId serverId, string sidIdentity, string roleId)
This method will check if the user identified by the provided identity is part of a specific role.
Parameters
serverId Server on which the role exists
sidIdentity Identity of the user to check
roleId The role to check
Ref. https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_util_1_1_security_access.html&tree=tree_search.html?search=ismember
Note. For a Windows user the SID is something you will need to ask Windows, hope you can find a method, for Basic users it is a Guid and you can find the users using Configuration API (CA).
I envision a solution where you
· Use CA to find all roles
· Use IsMember to find if the user belongs to a role
· Use CA to find the Camera
· Still using CA use the Camera method Edit permissions for each Role to see permissions.
I have not made the code, have not tested this, but I am confident it will work. Let me know.
Many Thanks Rie, I’ll implement and test the method then I inform you of results
Freddy
Hi @Rie Kiuchi (Milestone Systems)​
Any Sample plugin integration that checks camera permissions from roles.
How to use in plugin integration
  • VideoOS.Platform.Util.SecurityAccess.IsMember
  • VideoOS.Platform.Util.SecurityAccess.CheckPermission(Item item,string actionId )
Thanks,
Vikas
Regarding IsMember, there is no sample but please see this Forum question, it might be helpful for you to see how to use IsMember - https://developer.milestonesys.com/s/question/0D53X0000AO5kI7SQJ/check-if-the-logged-in-user-is-member-of-a-specific-role
CheckPermission, please see this sample. There are some code using CheckPermission so it might be helpful.
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/sensormonitor/readme.html&tree=tree_1.html
