Can "C:\Program Files (x86)\Common Files\VideoOS" folder be deleted safely?
The contents inside this folder are named randomly, I wonder if these are temporary files and folder. Can it be deleted without causing any issue to the application?
It is contain plugins capable of loading in the 32 bit Smart Client.
(In very old versions it could also contain plugins for Event Server or Management Application.)
I would say that if you do not use any 32 bit Smart Client it is safe for you to delete the folder.
