Can i Add a Plugin to Configuration Reports?
i would like to add a plugin that will show in the Managment Client 2020 R3, in the Configuration Reports Section, i want it in a new tab if possible.
is it possible?
if not, can i add my own Node to the main Site Navigaion?
thank your
No, the Configuration Reports “plugin” is not open for integration so you cannot add more to it.
You can place a node in the Site Navigation tree. I believe this older forum thread fits, if not hundred percent then enough to figure it out.. https://developer.milestonesys.com/s/question/0D53X00006WdqH0SAJ/placing-plugin-under-servers-node-tree-view-of-management-client
