Can I get audio capture by smart client?
I want to implement the talking with devcie function. Now I can get audio from device. And I want to get the audio that capture from smart client from milestone server use mip SDK .Can you give me some suggestion?
You can get audio from a speaker the same way you get audio from a microphone, just replace the microphone with the speaker.
If you want be able to speak using the clients microphone, please explore the Video Viewer 2-way Audio sample.
http://doc.developer.milestonesys.com/html/index.html?base=samples/videoviewer2audio_sample.html&tree=tree_2.html
This sample is standalone but you can use the same functions in the Smart Client environment in a Smart Client plugin.
