I cannot find a clue in any example provided with the javascript library.
Hi Alexandre, you cannot do that.
Br,
Nikolay
Hi Nikolay,
Thank you for your answer.
Can I do that with any other library provided by Milestone ?
Alexandre
Not with any API provided by the Mobile server…
I’m not an expert on other APIs but this forum thread seems related
https://developer.milestonesys.com/s/question/0D50O00003EIrxQSAT/startstop-record-manually-using-sdk
@Alexandre Quivy Actually there’s a workaround to achieve what you need via Mobile Server’s API, given you have pre-setup your VMS config.
First part - setup.
Open Management client and do the following configuration:
- Make sure recordings are enabled on your camera (mine is called ‘Bunny camera’, on the image below)
- Create two user-defined events (I have called mine ‘Start rec’ and ‘Stop rec’)
- Create a new rule and specify your camera and events
- Make sure you don’t have conflicting rules, e.g. a rule saying all cameras should record always.
Second part - requests to Mobile Server.
Beware - I’ll describe this in terms of our command protocol. I’m sure you’ll be able to relate this to the Javascript API (Web SDK):
- Call GetOutputsAndEvents and find in the response what’s the ID of your event - lines 12 and 13 in the code snippet below:
<Communication xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<ConnectionId>2daecd2c-ceb6-4761-98b3-4af0878b82da</ConnectionId>
<Command SequenceId="753">
<OEHeaderGroup Name="Outputs" CameraId="00000000-0000-0000-0000-000000000000" SubsCount="3" Type="OutputsGroup">
<OEGroup Name="Whatever Camera" CameraId="79be95fb-8abf-4391-96c9-0aafe625b0e8" SubsCount="1">
<OEItem Name="Whatever Output" ObjectId="0692e1c0-15fd-4711-89f2-e59949991b66" CameraId="79be95fb-8abf-4391-96c9-0aafe625b0e8" CanActivate="true"/>
</OEGroup>
</OEHeaderGroup>
<OEHeaderGroup Name="Events" CameraId="00000000-0000-0000-0000-000000000000" SubsCount="10" Type="EventsGroup">
<OEItem Name="Whatever Event" ObjectId="423a2d7c-a005-483a-a7be-ed61f38985eb" CameraId="00000000-0000-0000-0000-000000000000" CanActivate="true"/>
<OEItem Name="Start rec" ObjectId="31931ee0-43cf-4643-8730-ef7f5f2b37aa" CameraId="00000000-0000-0000-0000-000000000000" CanActivate="true"/>
<OEItem Name="Stop rec" ObjectId="2507d71d-006c-4624-95ea-09cb1576df76" CameraId="00000000-0000-0000-0000-000000000000" CanActivate="true"/>
</OEHeaderGroup>
<Type>Response</Type>
<Name>GetOutputsAndEvents</Name>
<InputParams/>
<OutputParams>
<Param Name="Challenge" Value="03323B58-12B0-4ED1-816B-345B86EF4BD6"/>
</OutputParams>
<Items/>
<Result>OK</Result>
</Command>
</Communication>
2. Call RequestActivation with the ID of the corresponding user-defined event. E.g. request to start recording:
<Communication xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Command SequenceId="771">
<Type>Request</Type>
<Name>RequestActivation</Name>
<InputParams>
<Param Name="ObjectId" Value="31931ee0-43cf-4643-8730-ef7f5f2b37aa"/>
<Param Name="TriggerType" Value="TriggerEvent"/>
<Param Name="Challenge" Value="4D78E159-989D-4616-AA05-A4854114CD63"/>
<Param Name="ChalAnswer" Value="YvwmTYWYQd53TzISfodvYFKlVtvVUzLlXwBchgbGw7mlP9eGrtcLy8R+v7bItJXizC+rNRtm2rvqmz1oZ5kEoQ=="/>
</InputParams>
</Command>
</Communication>
Br,
Nikolay
Hi Nikolay,
I had already this solution in mind but it requires a lot more work during deployment (specific configuration for each camera).
I also have to parametrize my integration code as it cannot know which ID to use until it is configured.
Thank you anyway.
Alexandre
