Can i use python to login and get the token for ImageServer? I am using ubuntu
Hello Ammer,
Were you able to connect to the Server and login using either of the Authentication methods? I would like to talk to you about the authentication because I am facing similar issues as well.
Yes
https://stackoverflow.com/questions/52150798/how-to-get-authorization-token-for-mipsdks-imageserver/52181196#52181196
Let me know if you are stuck
I have an essential + running on my local machine so should the url consist of Management server or ServerAPI this is what is getting me confused .and mentioning localhost in the place of server-ip should get it to work shouldn’t it because my server is on the local machine itself.
And are you passing the actual username and password in the header of sendall​?
Yes i am passing actual username and password but encoded to bsae64. Try any online editor to encode this ‘[BASIC]\your-username:password’
you can use localhost if you have the server in the localhost.
Can I get your email id. I have a couple of questions.
Thanks,
Sriman
Why did you use Management Server in your path when in the documentation they ask us to use either ServerAPI or ServerCommandService in the place of {Service_PATH}
Also, in order to connect to essential + which endpoint url should we use.
shahidammer@gmail.com
