Can We Apply Field-Based Filters When Fetching Audit Logs from the Server?
I’m currently using the following code to retrieve audit logs from the server:
VideoOS.Platform.Log.LogClient.Instance.ReadLog(
    MasterSite.FQID.ServerId,
    i,
    out _result,
    out _names,
    "Audit",
    fromDate.ToUniversalTime(),
    toDate.ToUniversalTime());
This returns all audit logs within the specified time range, but no additional filters seem to be applied.
In scenarios where there are a large number of logs, it’s very inefficient to retrieve everything and then filter by fields such as log type, source, user, or category on the client side.
Is there a way to apply filters (e.g., by user, source, or category) directly on the server side before fetching the logs?
Any suggestions or best practices would be appreciated.
No, this is not possible right now. But later this year we release a new way to store log entries, with new options for read and write.
Thanks for the response.
