Can we build VP service using visual studio 2015? or it requires 2017? because i am not able to load VPService project when it comes to VS 2015.
Hi Hala,
It is not possible to use Visual Studio 2015, it should be at least Visual Studio 2017.
You can also look at this link: https://stackoverflow.com/questions/42509313/the-default-xml-namespace-of-the-project-must-be-the-msbuild-xml-namespace
Best regard
Bent Nielsen
Thank you.
