I need to get from Milestone direct video URI for each of cameras.
The goal is to add XProtect cameras video feed into my application without using any MipSDK components, just by some normal RTSP or other Uri, which I would like to get from Milestone VMS.
Getting the video directly from the camera would simply mean bypassing XProtect and running in parallel to XProtect.
This is not recommendable because XProtect will change camera settings etc. without considering parallel clients. It is to my mind bound to result in problems.
You ought to retrieve the video from XProtect, not from the camera.
