I need to get Retention time and sequences start and end times from Archive storage. Can we get this using MIPSDK ?
Any sample is there for getting data from archive storage ?
You can get sequence data for the recorded footage on a camera, it does not tell you from which archive it comes. For an archive it is not possible to retrieve sequence data, it always takes the camera indiscriminate the archive it originates from.
You might know this sample that shows getting sequence data: https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/scsequenceviewer/readme.html&tree=tree_1.html
