Cannot Install Onvif Bridge on Windows 10
I am having trouble installing Onvif Bridge on Windows 10. The ONVIF bridge and RTSP services both abort. I pasted the error in the event viewer below. I have .net 3.5 SP1 and .net framework 4.8 installed along with the C++ redistributable. Is there something else I need to do?
Log Name: Application
Source: Milestone ONVIF Bridge
Date: 12/8/2020 2:24:59 PM
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: DESKTOP-8G5MHF6
Description:
The description for Event ID 0 from source Milestone ONVIF Bridge cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Service Start failed w/err 0xffffffff
Event Xml:
0
2
0
0x80000000000000
6735
Application
DESKTOP-8G5MHF6
