These commands do not work from inside the event server service.
(but they do work inside the PTZandPresets example)
Configuration.Instance.GetItemsByKind(Kind.Preset);
Configuration.Instance.GetItem(presetID, Kind.Preset);
Please tell me you have a workaround, I need the Item in order to get the FQID to trigger the preset.
I will try to browse use the items in Configuration.Instance.GetItems(ItemHierarchy.UserDefined)
to see if they are available. This is bad because I need to go through the whole config everytime I need a ptz position…
