Cant get the ShortCut property from the camera Item.
Hi i have set the “Shortcut” property from the Camera → Client Tab.
saved it.
In my plugin user control when using an ItemPickerForm with Kind.Camera.
I select the camera, but there is not “ShortCut” in the Item.Properties[“ShortCut”] (lots of other things).
tried to debug the VideoViewer sample found in the SDK and there i can see the “ShortCut” after selecting the same camera as my proj.
is this a security related?
any settings i missed maybe?
Thank you,
Or
The properties for an item is different in each environment.
Using the ConfigDump I could see that the ShortCut property is available in a Smart Client plugin and is not available in a Management Client plugin.
A possible workaround if you want the property on Management Client is to read it using the Configuration API.
If I am on the right track and you would like to get a tip on how to use the Configuration API in a Management Client plugin let me know..
Thank you​ for your answer, i would very happy to look in to it, if you could direct me to how to use the Configuration API that would be great.
Thank you,
Or​
While thinking how to best answer I got to think about this knowledge base article:
https://developer.milestonesys.com/s/article/exploring-the-MIP-SDK-recommended-top-SDK-samples
Please see the text in the Configuration API section.
Do not hesitate to ask for further guidance when having had a first glance at the recommended samples..
