Can't load live stream via SDK. Web client working fine
Hi
Can anyone advise please. I’m getting an error when I try to display a Live Stream via the Uwp Samples
ComponentSamples.VideoViewer and UwpSamples.VideoStreamingSample are both failing to load a live stream. I’ve tried it on 2 different Milestone systems. Milestone web client is working fine.
UwpSamples.VideoStreamingSample is firing the MediaFailed event with error “The byte stream type of the given URL is unsupported. (Exception from HRESULT: 0xC00D36C4)”
I’ve had to tweak the VideoParams slightly because the Sample was geared towards a Camera with Audio…
private static VideoParams GetRequestStreamParams(StreamParamsHelper.SignalType signalType, Guid cameraId)
  var videoParams = new VideoParams()
    ItemId = cameraId,
    MethodType = StreamParamsHelper.MethodType.Push,
    SignalType = StreamParamsHelper.SignalType.Live,
    **StreamType = StreamParamsHelper.StreamType.Transcoded,**
    FragmentDuration = TimeSpan.FromMilliseconds(-1000),
    DestWidth = 860,
    DestHeight = 640,
    FPS = 25,
    CompressionLvl = 71,
    StreamHeaders = StreamParamsHelper.StreamHeaders.NoHeaders,
  return videoParams;
The Cameras are set to H264
Any ideas/suggestions gratefully received.
Our colleague already discussed the same issue in another forum thread:
https://developer.milestonesys.com/s/question/0D53X00007W93cqSAB/cant-load-live-stream-via-sdk-web-client-working-fine
