Change the compression and quality of JPEGLiveSource
I will like to check when we are using JPEGLiveSource, what is the default compression and quality of the output? Are we able to change the value for these 2 properties?
We will like to have loss-less output when we are getting the frame from JPEGLiveSource.
Thank you!
JPEGLiveSource has a default compression value of 75.
If you explore the Media Live viewer sample you can see how the compression can be changed and you can play with the setting to see the impact.
