Change the generic event depending on the camera .ObjectId
Hello, I would like to know if someone can tell me what parameter I should modify with the name of the camera so that the event in the client is reflected with the one that corresponds to it, note that changing FQID.ObjectId for the corresponding one in the client is reflected , but this doesn’t make sense, I have as parameter input a camera name example; camera 1 and camera 2 that are the same ones found in the management server, how can I modify the camera so that it skips one or the other source, thanks
I am sorry, but we failed to understand the question, so can you elaborate on this? Or can you please explain what you want to achieve with the integration?
