Changing the IP address of a camera results in error "The server has lost connection to the camera"
The camera info has been updated in manager, and I can see the video from there, but after restarting services, the camera still doesn’t show video in the client application. Both manager and client are runnning on the same machine.
The recording server and management server will in newer version restart automatically to use the new settings. The Management Appplication is causing an extra stream to be sent from the camera, sometimes closing down the Management Application can make the camera start. Sometimes restarting the recording server and/or the camera does the tricks. Double check that camera and XProtect works with the same IP.
Note also there is a knowledge base article on “lost connection” with troubleshooting tips.
