Check your http/https connection
I tried to install the mobile Server but it keep says “check your http/https connection”.
I want to reach the Web Client with http, so I do not use a certificate. Below is the Error from the log file.
IIS is installed and running fine.
Kind regards!
2020-07-22;08:32:28;Error;System.ObjectDisposedException: The disposed object cannot be accessed
Objektname: “System.Net.HttpListener”.; bei System.Net.HttpListener.CheckDisposed()
bei System.Net.HttpListener.Start()
bei VideoOS.Mobile.Windows.Net.HttpListenerAsync.Start()
bei VideoOS.Mobile.Server.Service.MetaChannel.Plugin.Start(Dictionary`2 settings)
bei VideoOS.Mobile.Server.Service.MetaChannel.PluginGroup.Start(Dictionary`2 settings)
2020-07-22;08:32:28;Info;PluginManager.Start();This error might occur due to an incorrect HTTP/HTTPS channel configuration
2020-07-22;08:32:28;Info;LicenseWrapper;OnlineExpiration is False
