I have a plugin whose component in the ES environment needs to receive the Server.ConfigurationChangedIndication and SystemConfigurationChangedDetailsIndication messages.
If I change even just the name of a camera with the MC, the first message is generated, just as if I remove a camera, the second message is generated.
If I use the MC menu (RS->Device) “Edit Hardware” and change IP Address or even if I do a “Replace Hardware” no Configuration Update message is generated.
Is this correct?
Many Thanks,
Frediano
