Yes, this function is enabled if your server is XProtect Corporate 2020R2. If it is empty, the simplest explanation is, that you do not have any child sites to the site you are logged in on.
Does this fit or do you have child site that you expect to see but does not see?
Do you see a child site if using the Management Client Federated Site Hierarchy tab (the tab is found in lower left corner of Management Client)?
We have one theory on what might go wrong. Please build and run the ConfigAccessViaSDK sample, push the Show License button, take a screen capture of the resulting window, modify the picture to conceal the SLC (alternatively maybe your capture tools allow you to omit the first line with the SLC) and then upload it for us to see.
Your picture shows that our theory what might go wrong does not fit, so we can focus on something else.
We tried to reproduce your symptom but no success so far.
Please see what we did and please test this -
Make MFA (Milestone Federated Architecture): parent site is XPCO 2020 R2 and child site (older version; the version should be irrelevant for the issue).
Start ConfigAPI Client and log in to parent site with 2020 R2 SDK
If I am not mistaken, basic users cannot view/access child sites in a federated hierarchy. Can you verify that you’re also unable to see the child site(s) when logged in to Management Client or Smart Client with the same basic user?
At our customer, the clients are operated via Windows AD users.
However, our software must also communicate with all servers to control some devices and trigger custom events.
In our software we are currently using a Windows AD user to download the siteinfo.xml file and a Basic user for the SOAP interface to the individual systems.
To use 2 user accounts are ugly, but it works.
If the reading of the siteinfo information is only possible via SOAP, then it no longer works from Java.
Unfortunately, Basic users are not supported in Milestone Federated Architecture systems. This is not an issue introduced with the older XML feedback pages, the MIP SDK or Configuration API, but more a design choice pertaining to the VMS as a hole. You will find it stated in the documentation (Administrator’s Manual and help system):
