Hello.
We’re trying to connect to the VMS server on our network using the SOAP protocol following the TCPVideoViewer sample for guidance. But we run into a CORS issue. Is there a particular setting that we need to change on the VMS config to enable access? We don’t want to, and can’t, use the Mobile server hence need to make this work.
Any help or guidance will be appreciated,
Cheers
