Could not load file or assembly VideoOS.Platform.SDK.Media
I have the following error when I’m tring to run the following code:
Error:
Could not load file or assembly 'VideoOS.Platform.SDK.Media'
Code:
VideoOS.Platform.SDK.Media.Environment.Initialize();
I have added the following refs to the project :
  • VideoOS.Platform
  • VideoOS.Platform.SDK
  • VideoOS.Platform.SDK.Export
  • VideoOS.Platform.SDK.Media
Which can be found at:
" [C:\Projects\milestone-sdk-c\MilestoneVideoStream\lib\](file:C:/Projects/milestone-sdk-c/MilestoneVideoStream/lib/) "
(indicates that those were not imported directly from program files)
In addition this is the script running after each build
cd "C:\Program Files\Milestone\MIPSDK\Bin"
call CopyMedia.bat "$(TargetDir)"
call CopyExportFiles.bat "$(TargetDir)"
I have installed MIPSDK 2019R2
Do you have any clue?
Thanks.
I finally found a solution!
I had to change Platform target to x64 from Any CPU (in visual studio).
