Create bookmarks from the background with the SDK
I have a REST service in the background of my plugin that expects to receive a camera and thereby generate a Bookmark. I have been looking at the examples but they are through the protocol and need username and password. Is it possible to create boomarks from the SDK without a user?
There’s not much you can do with a Milestone server without a username and password. This will probably change in the future but for now you’ll need a basic or Windows user to do things like create bookmarks.
If you’re unable to securely store credentials on the machine creating bookmarks or there’s a password rotation policy that would make it inconvenient, I would consider creating a lightweight service to run on the management server under the network service context maybe, and build that service to require your client to supply an API key/secret. Authenticate with that little proxy with some API credentials​, and then it does the bookmark management from there as network service (or some other service account).
Thank you, can other users see the bookmarks of the user that I use in the plugin?
Sorry, it’s my first plugin in Milestone, I need any license to make it work? Because I get “The feature is not licensed” exception.
Yes, other users can see the bookmarks!
I recommend that you read here: https://doc.milestonesys.com/2020R3/en-US/feature_flags/ff_bookmarking/sc_workingwithbookmarks(547).htm?Highlight=bookmark
As the page hints bookmarking is not in all versions. XProtect Corporate, XProtect Expert and XProtect Professional+ has this, the lower product versions do not has this!
