We are trying to add the events in that i have facing the some challenges to assign a single event to multiple cameras or source, Can you help me to achieve my requirement . In below code i want to add the multiple source.
I have some doubts regarding XML tags and would appreciate your clarification. Specifically, I am curious about the
in XML. Is it possible to define and add my own custom tags within an XML. If so, could you please provide an example of how this would work?
Additionally, I noticed a tag called Vendor in XML documents. Could you kindly elaborate on the usage and purpose of this tag? How is it typically used to represent vendor-related information in events and alarms
In your given reference link is for bind the image from database it works properly in my code but I want the image snapshot of that camera where is my event is occurs for that particular time.
Could you kindly provide some guidance or suggestions on how to achieve this?
I think a lot of the design of XProtect is about the idea of not doing snapshots but instead opening the image by navigating to the time. The Alarm holds the camera id and the exact time. The Smart Client (SC) already will show the camera footage for the camera doing playback in the Alarm Preview!
If you do not use the SC but your own application you can using the information about camera and time ask for video from that time.
If you want to save an snapshot image please only do so because you have an image that is “more” that the camera image, in that case you provide the image and can send it as XML as outlined by the forum thread I linked.
