Create Investigations from the web sdk
I’ll like to have to possibility to create Investigations from the web sdk. I need to export and save locally a small piece of recorded video. I’ve seen the C# export sample but nothing for web sdk, so i’ve thinked about using investigations to create and download a file video.
I’ve seen how investigations work on the Web Client but I don’t know how, and if it’s possible, to create a similar procedure on a web page trough the sdk integration.
Thanks to all,
Best regards
Giuseppe
Hello Davide,
there is a sample in the web sdk (XPMobileSDK) which is called VideoExport which you can use to export video. I have made a video how to enable the samples so that you can see it in action: How to host Milestone XPMobileSDK samples.
I hope this will help.
Best regards
Teodor
