Create Layout
Hi, Is anyone know how to call builtin layout like (2x2) or (1+1) through SDK.
If you create a view item you will have to create a layout also. You cannot pick up the 2x2 layout in this scenario.
You can explore this in the Smart Client Dynamic view or Smart Client Insert Camera plugin samples.
I have seen the example, but there we need to define the layout manually by selection (Top, Bottom, Height, Width) size. But I want to call predefine layout which is available in video client.
See this post : https://developer.milestonesys.com/s/question/0D50O00003HiroBSAR/get-an-existing-view-for-camera-assigning?t=1489677445785
