I’ve managed to create a VideoWall, Monitor and VideoWallPreset from SDK.
But when I want to create/edit a MonitorPreset I will need to create/edit the DefinitionXml for this MonitorPreset.
Is there a way to generate this string/xml?
For example: 2x2 layout, camera 1-4 shown.
Thanks in advance,
Kenny
Rik
2
Video Wall Controller sample might be interesting for you.
https://doc.developer.milestonesys.com/html/index.html?base=samples/videowallcontroller_sample.html&tree=tree_search.html?search=video+wall+controller
When you run this sample, please set Select monitor and select using layout such as “2 x 2” then click “Send layout setting” at the
second box from the bottom. Also, you can select camera at the bottom box, set Select camera and Select monitor.
