Hi everyone,
I have a MIP plugin that need to send some custom commands to an external application. On the application I use _messageCommunication.RegisterCommunicationFilter(TriggerReceiver, new CommunicationIdFilter(“MyCustomCommand”)); in order to receive command. On MIP plugin I use TrasmitMessage to send command. If I trasmit the custom command, it is not received by the application. It seems only some kind of messages can be received from the application (MessageId.Server.NewEventIndication, MessageId.Server.ConfigurationChangedIndication, …). There is a way to implement custom message from plugin to application?
Thank you
