Hi there,
I have a plugin here in which I want to send a custom message from the admin plugin to the background plugin.
I have created a class “CallPresetMessageData”:
internal class CallPresetMessageData
internal static string CallPresetMessage = "DME.CallPreset";
public string name {get; set; }
public int preset {get; set; }
public object tag {get; set; }
In the “Definition Class” I add this to the “_messageIdStrings”.
In the admin plugin I trigger the send in a button event:
CallPresetMessageData callPresetMessageData = new CallPresetMessageData
Name = (string) ComboboxROIPreset.SelectedItem,
Preset = ComboboxROIPreset.SelectedIndex + 1
EnvironmentManager.Instance.SendMessage (
new VideoOS.Platform.Messaging.Message (CallPresetMessageData.CallPresetMessage, callPresetMessageData));
And in the background plugin I did the registration in “Init”:
_callPresetReceiver = EnvironmentManager.Instance.RegisterReceiver (CallPresetHandler,
new MessageIdFilter (CallPresetMessageData.CallPresetMessage));
But the event handler doesn’t fire when I call SendMessage:
private object CallPresetHandler (Message message, FQID destination, FQID sender)
EnvironmentManager.Instance.Log (false, "AutoPresetBoschPanoramicCam BackgroundPlugin", "CallPresetHandler Start call preset");
CallPresetMessageData data = message.Data as CallPresetMessageData;
EnvironmentManager.Instance.Log (false, "AutoPresetBoschPanoramicCam BackgroundPlugin", String.Format ("Message: \\ nName = {0} \\ nPreset = {1}", [data.Name](https://data.Name), data.Preset));
// CallPreset ();
return null;
Why is the event not triggered in the background plugin? Did I miss something there?
Best regards, Andreas
