Custom sensor display on map with flash when in alarms...
Hello.
What is the best practice to display custom objects on a map? I analyzed the SensorMonitor example but I don’t understand how to make the sensor flash from code, when the relative alarm arrives. I implemented a first solution using the user defined events, but it is too complicated and I would like to use the SensorMonitor mechanism which I really like. Thank you. Ciao. Gigi
