Customer is using Express 2014 and an Axis cam is giving me this error. mDNSResponder[2006]: Local Hostname axis-00408cfb3834.local already in use; will try axis-00408cfb3834-2.local instead
Axis has checked the cam and see no issue with it. The cam is a P6634-LVE
Hi Patrick,
do you actually have any issues with your XProtect sofware? Any particular symptoms or anything going wrong? (apart from that error message that, if I am right, may appear in your camera´s internal server report?)
Cheers!
Hi Raul,
As far as I know the Xprotect Express 2014 is running fine and all the other cameras are working. This cam was replaced a while back. We changed the mac and continued on. It’s been rebooting for a while. Support suggested defaulting the cam minus the ip address so I did that yesturday. Am going back onsite today or tomorrow to see if that helped. Hey thanks for the reply.
Hi Patrick,
you changed the MAC address? of the camera?
Ok, try a “Restore”, but we may need to know what you mean by changing the MAC…
Either way, you should monitor the camera at a lower level. If it is often rebooting, then there seems to be something wrong that is probably unrelated to Milestone.
