Customize ActionElement configuration UI
The plugin sample “BatAction” demonstrate how to customize the rule engine with a new ActionManager/ActionElement.
But in fact it seems that it’s only possible to create a particular item type requiring a bat file and absolutely nothing else !?
What about the configuration of another kind of ActionElement where it can be possible to customize the UI ?
The source that generated the event is also provided to the plugin - so for some integrations this will work fine.
We have added for 2017 R3 release to support 2 parameters in the action setup.
